跳转到主内容
加入维修社区 - 创建账户
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
iPad mini home button fix
So we have a iPad Mini which have a home button which is not working.
So does it usually fix the problem by swapping the home button?
Or can the problem be somewhere else and which makes the home button not working?
If the problem can be somewhere else than the actual home button then what else can it be?
I dont want to swap the home button if there is a fairly big chance it will not fix the problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Odds are pretty good that the issue is with the Home Button, the bracket coming loose or the flex being damaged. The only other option would be logic board but that is unlikely. However, removing an otherwise good digitizer without breaking it can be tricky for a DIY fixer.
这个答案有帮助吗?
得分 3
1条评论:
Thanks for your answer. Yes i have been removing the digitizer before, i thought the glass screen was the hardest part, especially when the glass was broken.
But is the actual home button hard to replace once one is past all the stuff that needs to be removed first?
完成的
添加一条评论
添加你的答案
Jon Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 4,917
