跳转到主内容
The second generation of Scion's box-shaped hatchback.
Aux to usb female for Bluetooth?
I'm trying to get Bluetooth in my xb but I don't need to upgrade my stereo. I just want to be able to play music, not make phone calls, etc. Has anyone tried an aux to usb female cord and a Bluetooth dongle for this? If so, has it worked? I know I can't use a Bluetooth dongle in the usb port itself.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
The problem here is the limits of your cars stereo system. Your Bluetooth dongle needs a driver from the system as it is not designed to offer this function you can't get it to recognize the bluetooth or set it up.
You'll need a device that has the smarts to do this in-between your phone & cars speaker system (via radio or USB)
An old phone hidden inside the glove box could do this. Pairing the phones via bluetooth: Radio > USB > Old Phone > BT > your Phone.
The other option here is getting a new car radio which has native Bluetooth
完成的
添加一条评论
3个答案
已选择的解决方案
I have a better suggestion.
So you notice you have some FM Stations that don't have an active station (just static).
You can use what is called an FM transmitter to wirelessly transmit your phone's bluetooth directly to the car's stereo via FM station.
Phone --> Bluetooth --> FM Tramsitter --> Car Stereo
https://www.amazon.com/Nulaxy-Wireless-B...
这个答案有帮助吗?
得分 3
1条评论:
This will work as a means to convert the bluetooth to a free radio station (tuned) as an input!
完成的
添加一条评论
It is possible to use a Bluetooth dongle with a car stereo's USB input. The problem is that most Bluetooth dongles are not designed for this and therefore won't work. You'll have to find a Bluetooth dongle that is specifically designed for non-computer USB inputs. These are usually labeled "car stereo" or "home stereo" or other terms to indicate they work without a computer. When you find one, however, it's a bit of a gamble if it will work or not since every car stereo's USB input can be a little different and every Bluetooth dongle is a little different. You might have to try 2 or 3 different Bluetooth dongles before you find one that works with your car stereo.
Here's an example Bluetooth dongle that MIGHT work: https://www.amazon.com/dp/B074WVJT6L
If you can't get a Bluetooth dongle to work with the USB input, the next-best options would be an auxiliary input cable or FM transmitter, like the other answers mentioned. The aux cable will give you the best sound quality, while the FM transmitter might be a bit more convenient.
这个答案有帮助吗?
得分 2
添加一条评论
This is the one I use for my 2010 xB and it's great. Usually connects right away and audio quality is good.
https://www.amazon.com/FIREFLY-Smallest-...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
TyTannik !!! 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 29
总计 2,278
