跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
Bixby Voice Doesnt work with Unlocked Phone
Hi there!
So long story with Bixby here.
I Purchased a Samsung Galaxy S8+ in the US from T-Mobile. I moved to canada, and got my Samsung device Unlocked. i now have it unlocked, and able to be used on network. Everything works fine, however i have found that bixby voice does not work.
I have bixby home working fine, and bixby voice is installed on the device, however, the bixby button doesnt do anything, and the Voice settings are not available on Bixby Settings.
I have spent a few hours on samsung support, and found that "bixby is not available on unlocked devices" (internationally unlocked). i find this to be discouraging, as you should get all functions of a device if your carrier supports it.
I have tried the following things to get this up and running.
1) Update the software: Device is up to date.
2) Reload the Firmware: Did not fix
3) Downloaded the ROM from Sammobile, and flashed it with ODIN: Same issue
4) Call provider to see if they could push the service to my phone: They can not
5) Call Samsung to see if they can get it running: Not supported on a device that was not originally that provider. (Dumbest marketing strategy i have heard.)
6) Call T-Mobile to see if they can help: i am no longer with them, so they will do nothing
7) Download Bixby Voice APK: installed fine. didnt change anything
I need help figuring out how to get this program onto my device. does anyone have any suggestions? I have a pretty decent background with phones, so ill take the more advanced suggestions as well.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
It works fine with a US T-Mobile phone flashed to the stock unbranded U1 firmware.
Don't reflash the T-Mobile ROM.
Flash the stock unbranded U1 mentioned on Reddit (can't find the link now) with the custom ODIN.
Then perform a factory reset with your SIM in.
Make sure you backup your data.
I also hope you didn't trip KNOX. I don't know if that has any effect.
这个答案有帮助吗?
得分 1
3条评论:
I plugged "Unbranded U1" into Reddit's search bar, and Google search, as well as XDA Developers search bar, and nothing seemed to come up.
also, i am only experienced with the basic Odin V3.0. im not aware of any "custom ODIN" do you perhaps have more intricate guidence you can give? The information itself is helpful, but i cant find anything you have mentioned anywhere.
完成的
Please read through this thread.
https://www.reddit.com/r/GalaxyS8/commen...
Do not flash until you fully understand it. I am not associated with this thread, but is whatI used to flash both a T-Mobile and Verizon phone.
950 is the regular S8, and the 955 is the S8 PLUS.
完成的
Hey there! thank you so much for the help. i found an answer similar to yours on XDA developers, but they were using other terminology for the items. thankyou for all the help. ill comment the link here that i found, and mark yours as the answer, as it got me on the right track. Thanks.
https://forum.xda-developers.com/gal...r...
完成的
添加一条评论
添加你的答案
Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 30
总计 1,130
