跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
Circle with diagonal after OS update.
So I restarted my MacBook after an OS update like it said to.
After a waiting bar upon start up it goes directly to a white screen with a white diagonal circle. I get the same issue after multiple restarts.
I haven't had any issues with my MacBook up until this point. I think it had something to do with this current update.
Any help is greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
So I fixed it by re-installing OS under the recovery boot up menu. laptop is operating like it never happened now. Thanks for your quick detailed response.
完成的
添加一条评论
2个答案
已选择的解决方案
First make sure you have the internal drive selected as your boot drive. Boot up under an external drive and then open the system prefs 'Startup Drive' and make sure the internal is selected and restart the system without the external. Hopefully that solves it.
If that doesn't solve it, it sounds like your HD or HD SATA cable is having problems. This systems SATA port is only SATA II (3.0 Gb/s) so you may need to review your drives spec sheet if its not the original drive that came with your system. Make sure it lists SATA II, if not you'll need to get a different drive.
You may want to replace the cable as the older ones did have problems. Here's the IFIXIT guide: MacBook Pro 15" Unibody Mid 2010 Hard Drive/IR Sensor Cable Replacement and here's the part you'll need: MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable
MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable图片
产品
$29.99
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
If you have one of these Macbook Pros:
  • MacBook Pro (13-inch, Early 2011)
  • MacBook Pro (15-inch, Early 2011)
  • MacBook Pro (17-inch, Early 2011)
  • MacBook (13-inch, Mid 2010)
  • MacBook Pro (13-inch, Mid 2010)
  • MacBook Pro (15-inch and 17-inch, Mid 2010)
  • MacBook Air (11-inch and 13-inch, Late 2010)
Then you can connect straight to the Internet via WiFi or Ethernet to download the latest supported OS X via Internet Recovery.
这个答案有帮助吗?
得分 2
1条评论:
This is only possible on the these systems after your firmware was updated with the ability. The original firmware did not offer internet recovery.
完成的
添加一条评论
添加你的答案
Phil Hovey Jr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 146
