跳转到主内容
Found a dime (coin) inside the DVD drive when replacing the battery
When replacing the battery on my device I see a dime inside the protective cover on the DVD drive. I assume it is not supposed to be there, but would appreciate advice about this and how to get it out.
Thank you.
Rosalie
Update (12/15/2017)
OK, I tried to lift the plastic sheet but it was adhered tightly and would not lift up. So, I carefully scored a small cut in the plastic by the dime and then pushed from the other side of the dime with a very small screwdriver through one of the openings in the plastic where screws are located. The dime gradually was pushed through the cut opening and is now out. I then placed a small piece of tape over the cut hole to seal it.
Now to see if the DVD drive works and if the battery will function as well.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Too bad it wasn't a Mercury (collector's item - silver) dime...
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Rosalie,
Your absolutely correct about how the dime is not supposed to be there, however in order for me to give you advice on how to get it out, I would appreciate if you could upload a couple detailed photos so I can see where it is and guide you from there.
- Chris
这个答案有帮助吗?
得分 2
4条评论:
Chris,
I posted 3 photos on the original question. Thank you for any help.
R
完成的
Wow its Heads ;-}
You'll need to carefully lift the sheet of plastic (curved side) enough to grab it with some tweezers. Don't lift the other sides as the flex cables could get damaged. Good Luck!
完成的
Thanks Dan, I'll try that!
完成的
Removing the plastic sheet to get the coin out, then readhering it isn’t going to have an impact on the CD drive, keep us posted! Sorry I didn’t get back to you sooner. - Chris
完成的
添加一条评论
添加你的答案
ROSALIE Frazier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 99
