Found a dime (coin) inside the DVD drive when replacing the battery
When replacing the battery on my device I see a dime inside the protective cover on the DVD drive. I assume it is not supposed to be there, but would appreciate advice about this and how to get it out.
Thank you.
Rosalie
Update (12/15/2017)
OK, I tried to lift the plastic sheet but it was adhered tightly and would not lift up. So, I carefully scored a small cut in the plastic by the dime and then pushed from the other side of the dime with a very small screwdriver through one of the openings in the plastic where screws are located. The dime gradually was pushed through the cut opening and is now out. I then placed a small piece of tape over the cut hole to seal it.
Now to see if the DVD drive works and if the battery will function as well.
1条评论
Too bad it wasn't a Mercury (collector's item - silver) dime...
由 Warren Buckles 完成的
