跳转到主内容
First released in 2010, the HP Compaq Presario CQ56-110US is one of the models offered in the Compaq Presario Notebook series.
comes on and goes off immediately
My Compaq cq56 comes on and goes off immediately keep for along time
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
@osaretin1234does it power down or is it just your screen that turns black?
完成的
I have the same with my Compaq615. At start up it gives one beep and powers down. It is plugged in and nothing comes on the screen and the power light goes off.
完成的
I have good battery, but it continually shut off right after turn on.. please help
完成的
Hi @ jonathan rivera
Does it do this with the charger connected?
If you have Win10 installed try starting the laptop in safe mode and check if it stays on.
How did you check that you have a good battery?
If you have Win10 installed create a Win10 battery report and check what it shows about the condition of the battery.
What have you tried?
完成的
Same exactly as me. Same fault
完成的
添加一条评论
3个答案
已选择的解决方案
Hi @maarmuis,
Usually 1 beep indicates a successful POST on HP/Compaq laptops.
Do you get the “splash” screen displaying on startup, before the “beep”?
Try a power refresh and check if this resolves the problem.
Remove the charger (if connected) and the battery from the laptop.
Press and hold the Power button for 30 seconds to drain any residual power from the laptop, then release the button.
Reconnect and switch on the charger to the laptop (leave the battery out at this stage).
Try to turn on the laptop.
If it starts OK, allow it to boot all the way to the Windows desktop (if you have Windows installed), wait for the HDD activity to settle a bit, then shutdown the laptop in the normal manner.
When it has completely shutdown, switch off and disconnect the charger from the laptop.
Reinsert the battery into the laptop.
Reconnect and switch on the charger to the laptop.
If it starts OK, allow it to boot all the way to the Windows desktop (if you have Windows installed), wait for the HDD activity to settle a bit, then check the charge status of the battery. if it is charging allow it to fully charge before switching off the charger and disconnecting it from the laptop.
这个答案有帮助吗?
得分 2
添加一条评论
There is a variety of things that could be going wrong with the computer, but there is a series of tests you could do to isolate the issue. Here's a question for you. Does the computer have a good battery? Does it continually shut off right after being turned on when plugged into a power source? Does the computer get past the HP logo and get to the Windows boot screen? And after the computer screen goes black, does the power light stay illuminated? These questions are all questions that will help isolate the problem.
这个答案有帮助吗?
得分 0
添加一条评论
Hello,
I have the same problem I disconnected everything; I just plug the charger into the mother board after a 5 min it power off; I checked the fan and processor witch are ok; I think that it’s a circuit in MB witch cause the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Osaretin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 26
总计 5,195
