The Motorola V325 is a clam shell phone, featuring VZ Navigator.
2 个问题 查看全部
Screen Blank, Keys light up.
My V325 has not been used for years. We recently need another phone. We recharged the phone and it starts (keys light up) but the screen is blank. Can it be fixed? Is there a reset button or something?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
The only thing that i know about the hard reset is to remove the battery and leave it out for a few minutes. To get into test mode do the following: Press CLR then 073887*. Turn on Test Mode and exit the menu back to your normal home screen. Then press CLR and then left softkey to activate FTS (Field Test).
To deactivate FTS and Test Mode, repeat the steps above, and turn Test Mode to off, then exit.
You may also have some LCD problem and may need to replace it. try the reset and take it from there. One step at a time.
Here is the SERVICE manual for you
Hope this helps....
这个答案有帮助吗?
按维修分数 3
添加一条评论
添加你的答案
Ron 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 626
