跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Power button not working
I have an iPhone 7 that has a power button that is not working. The volume works fine. The phone is up to date 11.2.1 and the power button is not loose or physically damaged. The phone has never been repaired. I tried restarting the phone by using assistive touch, but the phone goes into a boot loop until I plug in the charge cable. There is a warranty on it, but I find these symptoms very odd. Outside of restoring it to factory settings, does anyone have any tips or tricks?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
If your iPhone is still under warranty, then the best course of action is to go to the Apple Store for a repair. They will replace the device however so if you don't have a recent backup, then you should consider an independent repair shop as they can repair the device without data loss.
If you want to try something yourself, then follow this guide to see if the current power button is properly connected. You can also try to replace the Power Button Flex yourself.
iPhone 7 Audio Control Cable and Brackets图片
产品
$19.99
这个答案有帮助吗?
得分 2
添加一条评论
Try to restore using itunes.
这个答案有帮助吗?
得分 0
添加一条评论
Can anyone tell if this is caused by a defective power button. I’m also getting the same symptoms including the apple logo loop. Deciding to replace the flex now. I dont have warranty
这个答案有帮助吗?
得分 0
添加一条评论
I’ve even replaced power flex cable on my iPhone 7 it works for a little while but giving the same problem again, I’ve noticed whenever I open and close the phone it works for short time, I don’t know what to do
这个答案有帮助吗?
得分 0
添加一条评论
Simcard, don’t waste your time with these silly “repairs”
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian Wood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 7,232
