820-2879 LCD connector shorted now won't power up
Hi, I have an 820-2879 where the LCD connector locking arm shorted out the connector.
I have a green light on charger but no power up. I am trying to learn board repairs so thought a good one to start on.
PP3v42_G3H is at 3.48v but
I'm finding PPBus_G3h on the output of F7040 to be going from 12.8 - 2.8 pause then starts again at 12-8volts and goes down.
I am trying to learn so presume U7000 is what helps produces PPBus_g3h is that correct?
Q7030 has the same irregular voltage on pin 4.
Am I looking down the right line, can I have some help/advice please on where to go next?
Could it also maybe be something trying to turn on then can't hence why it goes back through the voltage cycle.
@mccltd this is of course after you changed the connector? Best person to let you know would be either @reecee or @tcrs_circuit
由 oldturkey03 完成的
Resistance between pins 17/18 and 27/28 of U7000?
由 TCRS Circuit 完成的
