跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Can not slide to unlock
i can't slide to unlock my iphone 3G i have tried the home button and the switch off button but nothing happens.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
7个答案
最有帮助的答案
hold down the power button and the home button at the same time and this will cause the screen to flash & afterward you want to hold down the power button & hopefully it'll turn back on. c: hope this helps!
这个答案有帮助吗?
得分 4
1条评论:
Wow yes it helped thank you my slide now works without replacing my digitiser
完成的
添加一条评论
I agree it does sound like you need a new touch digitizer. These can be found for relatively cheap ($10-$20) on eBay. The only problem with just replacing the digitizer is that there is a frame that the digitizer sits in/is attached to and that frame has the home button on it. Buying the whole assembly is about $60 on eBay. There is a step-by-step on here that shows you how to replace just the touch digitizer. I have followed this step by step and successfully replaced just the touch digitizer. My only warning is that you need to be really careful not to bend the frame that you'll be removing from the old digitizer. I bent the frame a little and the touch digitizer didn't fit in as well. Good luck I'm sure you can handle it!
这个答案有帮助吗?
得分 3
1条评论:
+ I agree but would probably replace the whole assembly because it is a little easier to replace since it does not require as much attention to the frame.
完成的
添加一条评论
you probably need to replace your digitiser. :)
这个答案有帮助吗?
得分 2
添加一条评论
hold down power button and the home button at the same time for 2 minutes
and this apple white should appear when phone turns on it unlocks
这个答案有帮助吗?
得分 2
添加一条评论
i need help i droped my phone screen cracked and couldnt slide to unlock and couldnt switch off got my screen fixed but still i cant slide to unlock whats the problem please be specific i cant go to main page stuck on slide to unlock
这个答案有帮助吗?
得分 1
添加一条评论
  1. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for eac== * Heading textitalic text ==h level of indent you want (e.g. ##)
这个答案有帮助吗?
得分 0
添加一条评论
My iphone 3s is not sliding cross and the screen is not working
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rouben 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 14
总计 15,115
