跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
20 个问题 查看全部
screen messed up after battery replacement?
I just replaced the battery on my iphone 6. did it while following a video... everything seemed okay. I removed the screen when I replaced the battery to avoid messing it up from what the DIYers had told me that would be best, so I took the screen off thinking that I'd avoid messing the screen up but now the screen is totally &&^&@@... its got lines running all through the screen and nothing is legible, and the touch doesn't respond. (i'm assuming it doesn't respond bc i can't see any apps etc, but touching the screen did nothing.)
What did/ could I have done to mess it up and is it something i can fix on my own or did I just waste money replacing a battery myself just to &&^& my phone up and end up paying for a repair anyway...
Any advice will help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
4个答案
最有帮助的答案
Check the connector ribbons on your screen. Make sure none of them are ripped. Then check the connectors themselves, on the screen and the board, make sure there's no damage to those. If there isnt any visible damage, then try reinstalling the screen. Be sure to click one side of the connector and then the other side until it clicks in completely. Don't push the middle. And then power cycle your phone. I think your data cable popped off which can result in black or white lines in the display. Did you keep the battery unplugged while you re-installed the screen?
这个答案有帮助吗?
得分 10
4条评论:
you just got 12 rep from me upvoting you. Congrats on 100 rep! keep up the good work!
完成的
Thank you so much! I will try. Now if only someone could help me with my question
完成的
Thank you! It works perfectly after unplugging the battery connector before installing the screen.
完成的
Thanks! I got the white lines on screen too. I took off cable connectors found a piece of the battery adhesive on one connector. Tried again same thing. Did another few times, still lines. I googled and found this answer. I then put together making sure i pushed connector one side at a time until clicked. That worked!
完成的
添加一条评论
Thank you!! Connecting the screen with the battery disconnected fixed it! It made me realize that EVERY TIME i tried to reconnect the screen the battery was still plugged in. Thank you so much! I could not have afforded a screen replacement too lol
这个答案有帮助吗?
得分 4
1条评论:
Great! I'm glad that is was an easy fix! Next time remember to unplug the battery when taking off and putting on the screen, otherwise you can short out the screen and blow the back light filter like I have done before. Im glad you didn't! :)
完成的
添加一条评论
I did it over and over in all ways it's still not working and I still got lines going through it. HELP!
这个答案有帮助吗?
得分 0
1条评论:
I got lines the first seven times i tried to get the screen to work but on the 8th time the screen works fine. Now all the touch sensitivities are going nuts
完成的
添加一条评论
You need to put the touch screen flex properly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tami B 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 75
总计 18,346
