跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Im replacing iPhone 5 with 6... 5 has 64gb, 6 has 16gb.
Im replacing iphone 5 with 6... 5 has 64gb, 6 has 16gb. Is there a way to reflash the 64gb to use in the iPhone 6.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
not sure what your wanting here? are you wanting to move the storage from one phone to the other?
完成的
Ah. hes saying he wants to take the 64 GB from his 5 and put it in his iphone 6, which has only 16GB. I think he wants a chip transfer. Not sure its possible.
完成的
I read an article where in China its very common a everyday thing. They remove the internal flash storage replace it with up to 128gb and re-flash (program) it so it operates as if it was native to it. the charge is $35 - $90 and they will do it in 30-60mins.
完成的
@captainsnowball does he want to change the chip or the whole logic board?
完成的
@sundaydriver yes this is possible if you have the ability to solder in the chip and if you have the ability to flash the chip. something there able to do in china because they dont care about legality
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
Unless you know and have the equipment to micro solder. No. Even if you could micro solder, It probably will not work. Yeah doing more research thats a solid No. 6 is made by Sandisk and the 5 is a hynix storage
这个答案有帮助吗?
得分 3
3条评论:
I don't think the brand has anything to do with storage. However, I think the pin configuration of the storage chips are completely different. Agreed, this will not work.
完成的
Well, at least I get the point out. I'm happy enough. =p
完成的
Thanks, the effort out weights the cost.
完成的
添加一条评论
添加你的答案
Richard W 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 80
