跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Display not properly working?
Hello,
My display for my Macbook Pro 13” is currently showing either white or striped purple lines. This started happening when I moved the display back. I moved it forward and it came back displaying normally but the stripes came back if I moved it back again. I decided to restart and now it does not go back to normal. If I try to increase/decrease screen brightness nothing happens. Same with keyboard brightness. Would this be a display problem or internal?
Update: Plugging hdmi recognizes the laptop but displays the same thing I would see on the laptop display.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I am assuming this is a iGPU or a GPU issue, since it does the same on an external display and the main display. The only way to fix this would to be to replace the motherboard. Here is the guide. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andy Lai (AndyAgility) 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 336
