跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Help with right temperatures for microsoldering
I want to replace the FPC Battery Connector Clip since its broken and my iphone wont turn on. what temperature setting should my hot air work station be set to and what temperature should my soldering iron be set to? any help would be greatly appreciated.
I tried to look for a youtube video or online guide for this procedure but was unable to find one. thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@freshstylez check with our expert @refectio or @teetopp for that.
完成的
添加一条评论
1个答案
已选择的解决方案
Soldering FPC connectors is tricky because too much heat will melt the plastic. The actual heat setting is not that critical because depending on how close your hot air nozzle is and how much air flow to the connector can make a huge difference.
Fundamentally speaking, you need to get the solder to flow. Depending on which alloy you use, you need to get the pcb/solder connection up to 183-190C. How you get there is what determines if you damage the plastic. You could blast it with 360C if you stay a reasonable distance away or you could go low at 275C and take your time. This is where the "artisanry" comes in...you have to practice a lot to get the right amount of heat to the pcb but not more than you need. As they say practice makes perfect.
Try different settings and see what works best for you. Some people like to tin the pads, others like clean and bare pads. Some like to "tack" the connector in place, others like to let the connector flow. Some like to do this with hot air, others like using micro-tweezers. It also depends on how much room you have on the pcb and how big the connector is. You'll need to develop your style, there is no set way to do this.
这个答案有帮助吗?
得分 8
添加一条评论
添加你的答案
Richard Rivera 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 6,088
