跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Hard drive and RAM
Kindly I want to asking about upgrade my Mac when I repair the hard drive and two RAMS, Expected will delete everything and must download software again right ?!
And the old hard drive will delete everything inside it? or I can use an external hard drive via USB ?
Thank you for support
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hard drives as well as solid state drives don't loose their content just by unplugging them. So you can take the drive out and then put it back and the system would be like it was.
As to upgrading think of it this way you have two shoes but only one sock so only one foot can have the sock! This is the same type of conundrum you face here! So how to over come it??
First make sure you have a newer version of MacOS installed, then create a USB OS installer following this guide: How to create a bootable macOS Sierra installer drive That way when you swap the drive out you can install a fresh copy of OS onto your drive.
The next step is to get this: Startech 2.5" SATA to USB adapter so you can plug in your old drive in - The spare sock you had in the drawer ;-} Now at the end of the OS install process plug in your old drive so you can then migrate your user accounts, apps & data over.
Thats It! Done
But! There is a few things more I would do here!
This series has a known issue with a bad HD SATA cable so I would take the time to replace when I put in the new drive. Follow this IFIXIT guide: MacBook Pro 13" Unibody 中期2012 硬盘线缆替换 and use this version of the part MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable. In addition I would place some electrical tape onto the upper case where the cable rests against it. As the ruff surface of the case is known to cause abrasion.
Lastly here is the IFIXIT guide to replace the RAM: MacBook Pro 13" Unibody 中期 2012 RAM内存条更换。
This cable connects a SATA I, SATA II, or SATA III hard drive to the logic board.图片
产品
$34.99
MacBook Pro 13" Unibody Mid 2012 RAM 内存条图片
指南
难度:
简单
15 - 30 minutes
MacBook Pro 13" Unibody Mid 2012 硬盘线缆图片
指南
难度:
简单
10 - 25 minutes
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the support!
完成的
添加一条评论
添加你的答案
HUSSAIN ALHASHMI 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 95
