跳转到主内容
Repair guides and support for your LG TV.
1341 个问题 查看全部
问题已关闭
Massage flashing on screen "This function is not available now"
I can't turn my Tv on or off or turn the volume up or down or anything else with it. It has a message constantly flashing on the screen like a strobe saying "This function is not available now" the only way to turn the TV off is to unplug it. It's connected to cable so we just turn on the cable box to watch TV the flashing message is constantly flashing 24/7. This has been going on for a month or more, it began we were watching something on DVR & about to leave I quickly rewound the program & turned everything off & returned to this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
14条评论
Same problem started while watching TV. Pls advise for solutions
完成的
Just reconnect cable again with setup box..
All three video and audio cable..
Reset factory setting..
Restart tv
完成的
There is no fix unless you get someone to repair it it’s burned something out on the motherboard I would advise just not buying LG and if u do don’t expect it cheap
完成的
How do u get it off the function is not avabile now
完成的
I have done that all, clean the sensor and switch panei, and opened the wires… But I get no changes… Please help me , what I hv to do next…!!!
完成的
显示更多的9条评论
添加一条评论
3个答案
最有帮助的答案
Sounds like a button is stuck down. What ever remote control you are using, take out the batteries, and try the physical buttons on the TV itself.
这个答案有帮助吗?
得分 3
3条评论:
No this did not fix the problem i've already tried this before I asked.
完成的
Hi..... Did you find the solution to this problem, also have this problem with my 47inch 3D tv
完成的
Me too.and the tv is keep on turning on so u have to unplug it...
完成的
添加一条评论
The buttons on the TV failed, check the controls on the actual TV.
You will need to open up the TV and pull out the button control PCB board and disconnect the wire harness connector from the board. The TV is easy to open, use a Philips screwdriver and open about 3 quarters the side where the controls are, you do not require to disassemble the entire unit, just enough to remove the button control PCB board.
The TV should work without the “This function is not available now" error. If you don't use those buttons(you have a remote), you do not need to replace the button PCB board.
这个答案有帮助吗?
得分 3
9条评论:
Thank you! I did the same thing with my tv i opened it and disconnected the wire button remote on my tv. And it works! I tried so many things before i did this. Mine also opens by itself so the first time it happened it was in the middle of the night imagine my horror. Sooo glad i did not buy a new tv. I suffered for 3 long years. Urrgh
完成的
I simply opened the tv and unplugged the side panel. This would require you use a remote but it works
完成的
how do you open the panel?
完成的
I have it too.
It’s seems that the touch panel had dirt on it. The sensor feels like we pressed something.
Cleaned up the touch panel.
I hope it’s the end of it.
Yaakov.
完成的
Touch panel? Is that the on/off button of the tv?
完成的
显示更多的4条评论
添加一条评论
This is a problem that happens due to dust and mostly will happen to TVs which are about 5-6 years old (lesser if the environment is dusty)
SOLUTION:
First of all clean the IR output area of the remote control with a slightly wet cloth as well as the IR sensor / touch panel area on the TV
There are 3 possible reasons for this display of "This function is not available now"
1.      Your remote is pressing a button which is not applicable in the viewing scenario e.g if there is a “PROGRAM UP” button pressed on the remote when you are watching something from a set-top box. So “PROGRAM UP” button function will be not applicable and hence the error. This error will go off after 10 seconds. Sometimes the remote button gets stuck and you don’t come to know - which will result in the error
Solution : Watch the remote IR output through your mobile camera - do you see some light blinking constantly without your pressing any button. In this scenario, your remote battery will get discharged very quickly i.e within 3 days. Try to turn the remote away from the TV IR sensor for 10 seconds and the display "This function is not available now" should go away.
If the above does not solve the problem, then this next step follows
2.      There has been a malfunction of your TV’s IR sensor circuit / touch panel (generally due to some kind of water damage
Please try the following : Open your TV back cover and remove the cable connector of the motherboard that goes to the touch panel / IR sensor area. If doing this removes the display of the error "This function is not available now", then the problem lies in the TV’s IR / touch panel circuit. Switch off the TV Take out the IR sensor / touch panel PCB and clean it with Iso-propyl alcohol and replace it back.
If this too does not solve the problem, then this next step follows
3.      There is a overheating happening to main processor on the motherboard (processor chip is most probably the only component with a heat sink attached to it).
The solution is to take a soft brush and remove all dirt over and below the heat sink. Take an air can (high pressure air) and blow it over the main processor as well as on its sides. At times the heat sink is slightly larger than the processor and there is a small gap between the oversized heat sink and the main board below it. This is the place where there might be some dust accumulated and could be the reason of this error.
In case this does not solve the problem, then the last thing to do is to remove the heat sink from the processor (pls refer the heat sink removal process by pcbjunkie youtube video : https://www.youtube.com/watch?v=W7oL3sfz... ). After heat sink is removed, clean the area with the soft brush, use air can to remove any dust particle in the area. Now clean the surface of the processor IC and heat sink with Iso propyl alcohol. Re-install the heat sink using 3M heat sink tape and ensure there are no air bubbles between the heat sink and processor. Once this is done, your error "This function is not available now" will vanish.
Thanks, Vishwa
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 26,575
