跳转到主内容
The OnePlus 5 (OP5) is a 5th generation smartphone released June 20, 2017. It is the successor to the OnePlus 3T and predecessor to the OnePlus 5T.
52 个问题 查看全部
Is it ok to use isopropyl alcohol 98% for OP5 back?
so i have this stains in almost every side of my phone back, i think its from the case i bought but i dont know and i wanna try to clean it with isopropyl alcohol 98% is it ok, my worry is would the paint rub off?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Iso wipes or using the alcohol on a soft towel is OK to use. If you find that the wipes don't clean it good enough dawn and water on a soft towel with very light rubbing will do it. As you long as you lightly rub/wipe it the paint won't come off. Tip:Don't use bathroom towels. Microfiber is your friend here.
这个答案有帮助吗?
得分 0
2条评论:
So just use microfiber towel and isopropyl alcohol? Should i mix the isopropyl alcohol with something, like water?
完成的
No, don't mix the alcohol with anything.
完成的
添加一条评论
添加你的答案
Gamas Lazuardi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 362
