跳转到主内容
加入维修社区 - 创建账户
有关用于特定任务(如固定、建造或切割)工具的维修信息。了解如何使用有效的工具来修复坏了的工具。
Pro Tech Driver wobbly bits
Quick question about the screwdriver and the bits: Are the bits supposed to be wobbly and loose when attached to the driver? They stay in the coupling just fine but have a lot of side to side play. Is this normal/by design? If so, why was the driver designed this way?
Thanks in advance~
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
There's a little play but not wobbly. Can you give a link to exactly which driver you got (they have changed over the years).
这个答案有帮助吗?
得分 3
9条评论:
Thanks for the response Mayer! I believe this is the new 2016 version, it came with the recent Fix the World special.
https://drive.google.com/file/d/1B2wB3LL...
完成的
[关联产品丢失或禁用: IF145-360]
完成的
I just tested mine and there is little play in it but I would consider it wobbly. Take a look in the driver hole and see if the might be something in there (like a tiny screw) that would prevent the bit from fully seating.
完成的
Looks clear, just the barrel and the magnet. Are you able to roll the bits around in yours, making a light clicking sound? I realize that "wobbly is a pretty subject term so my apologies XD
完成的
I can turn it just a hair. There is certainly not enough play to make it click. iFixit does give you a lifetime warranty on it if you feel it is defective, they will be happy to replace it.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Haoqian Wen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 389
