跳转到主内容
Released in 2011, the Asus K53SV is a 15.6-inch laptop with a 2nd-generation Intel processor and a dedicated Nvidia graphics card.
5 个问题 查看全部
Can I replace my existing K53SV motherboard with K53SM motherboard?
Hello,
I bought Asus X53SC-SX224D model on 2011 which has following specs:
- Motherboard: X53SC - K53SV REV 3.0 (PCB MADE IN CHINA)
- RAM: 2x2GB DDR3 1333
- Graphics: GT520M 1GB VRAM
- Battery: 4400mAh 4-Cell
- Processor: 2.3GHz i5 2nd Gen Processor
- DVD Writer
Now, this motherboard was damaged and I'm planning to fix it or replace it.
Can I get a new K53SM motherboard instead of K53SV? Will K53SM motherboard supports all my existing external hardware components?
Are the motherboards part number specific?
Can we use 1600mHz DDR3 RAM?
Existing K53SV: https://www.empowerlaptop.com/p/asus-x53...
New K53SM: https://www.empowerlaptop.com/p/asus-k53...
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
You can replace your motherboard with the one you want to replace it with, they should be compatible.
As for your second question, about the RAM, you can use DDR3(/L) 1600mHz DIMMs, but they will switch automatically to 1333mHz regardless because 2nd gen Intel Core i-series chips don't support faster speeds.
这个答案有帮助吗?
得分 1
2条评论:
Thanks Alex.
完成的
is the ks53m better than the ks53v?
完成的
添加一条评论
添加你的答案
Prasanth G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 1,181
