跳转到主内容
SSD detected but not bootable?
Have a Crucial SSD that was previously in my early 2010 MBP with no issues. I upgraded to a Late 2011. When installed in the HDD port it's not detected at all. When in a housing connected by USB it's not detected during the boot sequence. If I boot from another HDD and plug in the SSD using USB it's detected and readable (but not bootable according to disk utility.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Just wondering have you used Disk Utility's repair disk function?
完成的
Disk Utility said there was an error but I needed to go into recovery mode and repair it. Unfortunately I can't enter recovery mode unless I can boot from the disc. I reformatted and copied the HDD back to the SSD using SuperDuper and still have the same issue. Thanks!
完成的
@mrodgers you have a 2011 Macbook Pro, right? You don't need a disk to boot to recovery. You can either use WiFi or an ethernet cable to boot to Internet Recovery Mode.
http://www.idownloadblog.com/2016/02/25/...
完成的
Cloning software images what it finds on the old drive to the new one so if the old drive has any issues the are copied over. I don't use cloning software I stick with Apples Migration Assistant. Yes, its slower! But unlike the cloning software its leveraging the check sums within the files to make sure they are not corrupted. Besides the hidden partition is often overlooked so you give up the onboard recovery option.
Refer to @avanteguarde note above to get your system going after you replace the cable. Then use Migration Assistant to copy over your stuff.
完成的
I had a similar problem whenI replaced my early 2011 logic board with a mid 2012. I even replaced the HD cable but that did not help. The trick was to use an old HDD with MAC OS Sierra, then upgrade it to High Sierra and then the logic board was able to boot from the SSD again. Read this article:
Hard Drive/OS not recognized after logic board replacement
完成的
添加一条评论
1个答案
已选择的解决方案
You've hit the classic case of a broken-down HD SATA cable!
You'll need to replace it following this guide: MacBook Pro 13" Unibody Late 2011 Hard Drive Cable Replacement and this part: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable This is the better version of the part. I would also place some electricians tape on the upper case where the cable crosses as a common issue is the abrasion against the case wears the cable over time.
Do be careful at the bends over stressing them can break the foil traces inside (which is what likely happened here)
As far as why the external case failed I suspect its an older SATA II (3.0 Gb/s) case. The drive your working with is a SATA III (6.0 Gb/s) which I do believe is a fixed speed drive.
Give this unit a try: Startech 2.5" SATA to USB adapter
This cable connects a SATA I, SATA II, or SATA III hard drive to the logic board.图片
产品
$34.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mike Rodgers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,640
