How do I pair my phone or tablet to my echo dot?
Is their a pairing button or does the echo dot automatically connect to the nearest device in range?
Hi there! Make sure the bluetooth is turned on on both your iPhone and tablet. Say "Alexa, pair," and select the Amazon Echo from settings to connect. For more help visit the troubleshooting page here: Amazon Echo Dot 2nd Generation Troubleshooting
这个答案有帮助吗?
You've must've lost your manual. Here you go!
这个答案有帮助吗?
You can stream audio from a mobile device because echo dot is Bluetooth-enabled. Here you can checkout how to pair your phone with echo dot:
- First of all, open your Alexa app.
- Select Settings by opening left navigational panel.
- Select your echo device then select Bluetooth> Pair a new device.
- Open Bluetooth settings menu on your mobile device and your echo dot device. It make take a few seconds to appear in the list.
If still, not pairing device to Bluetooth, read this Echo Dot Bluetooth Troubleshooting
这个答案有帮助吗?
Hi
I feel it's my privilege that I have got a chance help you . To avail entire help for all Echo dot related bugs visit: Echo dot Setup
这个答案有帮助吗?
Sometimes, there can be Bluetooth connectivity issues, to tackle this problem, you can unpair and repair the device. For this, go to setting and then Alexa app, now click on the Bluetooth option and clear the paired devices. alexa not responding
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 33
过去 30 天: 105
总计 22,600
