Samsung starts, gives a message after a few seconds then restarts.
Hey, I'm looking on an Samsung s2 (9100) that been dropped and after that it starts a few seconds then gives a message that something can't load (? Don't remember exactly) then it restarts and does the same all the time. The motherboard gets pritty hot in the upper area.
Seen some that removed simcard and then could save all files and update it.
I only trying to save all pictures. Tested several programs for it Dr.phobe etc but nothing works.
If I put it download mode and the other mode it dosent restart.
Any tips?
6条评论
Could you please provide the exact error output?
由 Xacobe Cimadevila 完成的
It says something like "Can not retrieve now, please try again later" (Google translate from Swedish to English.)
Many have said the power button is the problem when I have searched buy there's no difference without it connected
由 Jonny 完成的
@benjamen50
The data is the only thing I'm trying to save
由 Jonny 完成的
@avanteguarde yes that works
It gives me these options
Reboot system now
Apply update from ADB
Apply update from external storage
Wipe data/factory reset
Wipe cache partition
Apply update from cache
由 Jonny 完成的
Ok, if the phone does not continue to restart, then you have a stable environment to retrieve files.
I can't remember if stock recovery allows you to run adb push/pull commands.
See this article.
http://www.droidviews.com/push-pull-file...
If adb does not work, you will need to install TWRP recovery.
https://twrp.me/samsung/samsunggalaxys2i...
You can put an SD card in the phone, if there isn't one, and copy the files from main storage to external storage with the adb commands.
由 S W 完成的
显示更多的1条评论
