跳转到主内容
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
256 个问题 查看全部
My GALAXY NOTE EDGE WONT TURN ON
Hi , i need help, i have the same problem on my GALAXY NOTE EDGE , I posted here because it seems that Note 4 and Note Edge are similar, anyways , my phone started freezing and working slow , and lately started shutting off by itself and demanding a reboot and it didnt work so everytime i take the battery off for a few minuts and turn it on again and it works after trying for couple times or sometimes he start easy from the first try, and it keeps doing that for about two weeks , but last night he shut off and never came back to life , i tried everything , the repoot trick by holing the home buttom nd the volume one , tried to take the battery off and hold on the power key for 1 min , 2 min, 3 min .... and more and then put back the battery and never owrked to ... i dont know what to do , i dont want to loose my phone , arround 10 GB videos and picturs and documents are stuck there and i dont know what to do, do please any help ???/ any suggessions ??? sorry for my english if there is any mistakes , PLEASE LET ME KNOW IF THERE IS ANY MISSING INFORMATION
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Try a new high quality battery replacement. The Note 4/Edge are strangely sensitive to batteries.
这个答案有帮助吗?
得分 1
添加一条评论
Sounds like a bad battery. Replacing it will most likely help. If this doesn’t work, it may be the components inside the phone that the battery connects to. Sadly, I couldn’t find a teardown for this device.
这个答案有帮助吗?
得分 1
添加一条评论
Take out the battery, put the phone in the freezer for 5 min, take it out, put battery back on power it and when it turns on plug it to a charger
Is a temporary solution, the phone will shut down eventually, I'm trying to find a real fix
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MANNAI 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 3,287
