跳转到主内容
加入维修社区 - 创建账户
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
LCD does not get Power
Macbook was stepped on in the left upper keyboard area by the hinge to LCD. The LCD did not crack. The Macbook still drives an external monitor fine with everything working. The monitor is just pitch black. Unsure if the inverter was damaged or some cable assembly that goes to the display. Any ideas or troubleshooting advice is appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You most likely have a damaged cable. Could be the display data cable or the inverter cable. You will need to open it and visually examine the cables and connections. Here's a very good place to start.
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Display Data Cable Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kenkaufman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 541
