跳转到主内容
加入维修社区 - 创建账户
Announced in October 2013, The Nikon D5300 is an upper-entry-level DSLR with a 24Mp DX-size sensor.
My D5300 won't turn on
My D5300 will not turn on. When I put the battery in and turn the switch to on the green light flashes but the camera does not turn on. If you look through the viewfinder it shows that the battery is low. I have tried 3 different batters charged by different battery chargers. I have also tried 3 different lens sizes.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论:
Take your lens off and put the body cap on then try turning it on. Put an SD card in or take it out.
完成的
Even my camera stopped working. all of sudden its not turning on tried removing the batter sd card didn't work out is there any solution for this?
完成的
添加一条评论
2个答案
I have encountered this issue. I tried the suggestion and nothing happened.
Did anyone find a solution?
I would appreciate any help.
这个答案有帮助吗?
得分 0
添加一条评论
I had this same issue. I thought my battery was old hence this issue so I purchased a new battery. Even that didn't work.
Don't know why but I slapped the camera from all side and it started working again. Ithibk this must happen due to some loose connection in my case. As I encountered the same problem after few week and I tapped the camera on all sides and it started working again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charlene Frink 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 48
总计 5,932
