跳转到主内容
加入维修社区 - 创建账户
第三代起亚 Kia Rio 于 2011 年 3 月 1 日在日内瓦车展上首次亮相,依然基于现代 Hyundai Accent 打造。
Vehicle won't crank over
Vehicle won't crank over. I've replaced the crankshaft sensor, checked the alternator, battery, starter, coil packs, and replaced the spark plugs. And replaced the fuel pump. Just won't crank over. Any suggestions
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
If you have a no crank situation and you have a good starter for sure then look for possible wiring issues . Look closely at the grounds. Check for engine codes as well . When you attempt to crank the car do you loose power to lights check the voltage at the battery as you attempt to crank . If you loose all voltage it could be a week cell in the battery that only shows up under draw conditions . Hope this helps
这个答案有帮助吗?
得分 5
1条评论:
Did you find out what was wrong? Im having the same issue with a Kia Rio 2011
由完成的 分享
添加一条评论
添加你的答案
Royce J Daniels 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 18
总计 6,363
