跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 个问题 查看全部
I cant connect to the internet through airport
I've just installed a new hard drive into my I book and successfully installed Mac OS X but i cannot connect to the internet through airport can anybody help please. I have an airport card installed and tried everything.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
What system did you install, how much RAM do you have, what are the last three letters of your serial number?
完成的
Were you using this on the wireless network before the HD / OS upgrade?
完成的
添加一条评论
2个答案
已选择的解决方案
Go under the Apple in the upper left hand corner to "about this mac", more info -> Network -> Airport and see if anything is listed. If nothing is there the first thing to do is check its connections, if they are good then replace the card. Here's how:
iBook G3 12" Airport Replacement
这个答案有帮助吗?
得分 3
2条评论:
There is no more info option hear and all connections are good but when i go to search for anything on the internet i get the message "the specified server could not be found"
完成的
If there's no information on the card, then the computer does not see it. Try reseating it, if it still doesn't see it, then replace it. I see on the answer to machead your are getting good signal strength, please explain what's happening.
完成的
添加一条评论
If the card shows up in System Profiler it's seated properly, you could have disconnected/damaged the antenna connection. No card listed means check the seat of the card, verify the card.
Remember to return and mark as accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 3
3条评论:
the card is not damaged in any way as far as i can tell and i get good signal strenghth
完成的
Then it's your wireless network. Is your router listed? Under System Preferences->Network->Advanced->TCPIP what is listed?
完成的
"the specified server could not be found" means your DNS service OR FIREWALL is not working, provided you have a valid IP address (not 169.xxx.x.xxx) What do you have listed in System Preferences->Network-> Advanced->DNS? Your internet provider may have some DNS server numbers for you to use, OR on the Search Domains you could enter google.com, earthlink.net, aol.com
完成的
添加一条评论
添加你的答案
Richie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 7,151
