跳转到主内容
2015年十一月,华为发布了Mate 8。Mate8搭载了安卓6.0系统,具有6英寸的屏幕。有32GB以及64GB的内存,3GB的RAM以及4GB的RAM两个版本,一个16MP的后置摄像头和8MP的前置摄像头,一个4000毫安时的草鸡大的电池
Replacing battery without battery adhesive strips, ok or not?
I've already bought a new battery and about to replace it into my Huawei Mate 8. I watched the video showing how to replace the battery from Youtube which mentioned that once taking out the old battery, I need to place two adhesive strips to stick the new battery into the tray. However, I don't have the strips. My question is "Can I just ignore it, and continue replacing the new battery without the strips, or I should buy stripes to make sure everything is good in the long run.
thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
You could just install the new battery without the adhesive strips, I think it will still be held in place by the other components. However it may start moving around if you shake the phone if you don't stick it in there like it was.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Pichai Tachalertsuwat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 304
