跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Wifi grayed out iPhone 7
How i can fix my iphone wifi?
It’s not working also Bluetooth.
I need the wifi antenna part to replace.
Where i can order?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
This is not an antenna issue, replacing the antenna will not work.
You have to get board level repair.
这个答案有帮助吗?
得分 3
4条评论:
How can i repair? Help me with some guide. Do u really think that if i get repair the board level everything will be ok and the wifi still not grayed out?
完成的
Most the time it is a board level repair.
This video should be helpful for you
https://m.youtube.com/watch?v=FDY4zFv1RU...
完成的
Before you do board level repair, you should check one thing. Does the wifi show an address in the "About" page in the settings? If yes, then restore phone. If it shows "NA" in about page...then you have a board problem.
完成的
a little late on the topic. my 7 was experiencing this issue. tom and the others are certainly right in regards to module replacement/ repair. but i went the poor mans repair route. i removed the board and heated up the module at about 350 F for 10 minutes and clamped it until it cooled back down. added support underneath module. reassembled. experienced success for 2 days, wifi grayed out again. proceeded to remove the two standoff screws near the top right of the board. reassembled. wifi/bluetooth hasn’t been an issue for about a month now. i’m sure its only a matter of time before another issue but fingers are crossed.
完成的
添加一条评论
I get my screens from cellphoneage and all other parts from eBay, I always make sure they are American sellers tho or you will wait a long time for it to come in the mail from China lol.
这个答案有帮助吗?
得分 1
2条评论:
What does this have to do with WiFi greyed out issue? And why mention parts sellers on a site that sells parts?
完成的
Because people can say or post what they want. You got any issue with that? Move to China.
完成的
添加一条评论
添加你的答案
Ori borici 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 29
总计 36,453
