跳转到主内容
加入维修社区 - 创建账户
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
System won't start any more. The diagnostic LED's aren't lit
Good morning, my name is Andrea and I'm a hardware technician at the Ministry of Finance in Rome.
I have a iMac i5 2011 that does not start anymore. The diagnostic LEDs do not even light up. I changed the power supply but nothing.
I realized that the damage is on the motherboard. Is there a fuse or capacitor I can control?
thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Ciao! Andrea. Is this a 21.5" model or the larger 27"?
完成的
@andrea71 what is the 820-xxxx number on your logic board?
完成的
is a 21.5 model, today i put a new power supply and now only lights up the led 501, the mac start and goes off but then turns off then turns on then goes off continuously and the fans go to the maximum.
完成的
It stays on with the new power supply? You should have a model number on the logic board that starts with 820- you need to look really close to see it. The fans should rev up when you turn it on without the lcd.
完成的
my model number is 820-2641-A
完成的
添加一条评论
1个答案
已选择的解决方案
Solved......my problem is video card.....I removed the video card, the mac is back normal, you hear the bong .....
thanks to everyone for help, now i just have to buy a new video card .....
bye from Rome.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrea 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 217
