跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Can I upgrade to another C2D processor?
I have processor Intel C2D 2GHz. I would like to upgrade it to 2,4GHz. Is it possible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi!
Unfortunately you can't upgrade the only processor since it's soldered to the logic board. You'd have to replace the entire motherboard.
这个答案有帮助吗?
得分 5
添加一条评论
It is complicated and difficult. but you can try as I have tried many times and also take the help of some experts.
Soundcloud customer service
这个答案有帮助吗?
得分 0
添加一条评论
Complicating the matter for Intel CPU users is the plethora of socket formats that may be involved. At last count, Intel had four active socket formats for desktop PCs: LGA775, LGA1366, LGA1155, and LGA1156.
这个答案有帮助吗?
得分 -1
3条评论:
MacBook Pro's don't have socketed CPU's
完成的
Thank you for responding. But how it is possible, that motherboard do not have socket?
完成的
@tuteraz Well, you can change the processor if it is in a socket, because a socket just keeps the chip pressed down alligned with the pins. The socket then connects to the board. MacBooks do not have sockets because the chips are basically glued directly on the main board.
完成的
添加一条评论
添加你的答案
Michal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 118
