跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
iPhone 7 Boot Loop issue with Front Camera/Proximity sensor
I have an iphone 7 that is stuck in a bootloop after screen replacement. The phone was working fine for about 2 weeks, then customer called and said his front camera, mic, sensor, etc was not working anymore. Ive narrowed it down to the proximity/front camera/earpiece flex. When its disconnected phone powers up fine but when reconnected goes straight back into bootloop again. Have tried replacing flex cable with 3 other spare ones, no luck. I'v also tried unplugging the home button extension flex cables without any luck. Tried replacing the screen with 3 others screen as well. The only thing I wasn't able to try is an original apple screen and home button assembly.
I have seen other people experiencing this issue as well on this forum, would definitely like to know what's going on. This looks like software related... is this because of 3rd party screens?
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Did you end up resolving this? i have same issue
完成的
添加一条评论
2个答案
已选择的解决方案
In short yes, it seems apple has programmed something into iOS 11 which detects 3rd party screens and causes the operating system to "malfunction" its has various symptoms such as digitiser only responding to every second input for example. I have had some success in restoring through DFU mode, but only on a few phones. My company has stopped iPhone 7 screen replacements for this issue.
这个答案有帮助吗?
得分 0
2条评论:
So a replacement sensor cable won't resolve the issue?
完成的
I dont believe this to be true, we have repaired hundreds of 7's with 3rd party screens and only around 1% have been faulty, nothing to do with IOS.
Youve either damaged the home button, the frnt facing camera or the screens touch id/hb flex is faulty.
Try either a new screen or front facing camera and re do the steps.
完成的
添加一条评论
My experience was when that happens, I unplug the home button. It fixed my problems.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jason Savoie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 38
总计 1,522
