跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
Beta 2 killed cell service
After installing Android o beta 2 on T-Mobile galaxy s8, my phone will not connect to mobile network and does not have an IMEI number. When I restart, it activities service but then it says com.android.phone has stopped. What do I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
i am assuming you tried to flash the OEM stock rom back to the device?
完成的
Nope....I would like to keep my files. And Samsung members and Samsung + won't let me in....
完成的
well i was once a samsung warranty technician, and the first thing i would try in this situation is flashing the OEM software.
curious, did you use a certified samsung channel to flash the software onto your phone?
完成的
添加一条评论
2个答案
已选择的解决方案
I would attempt to back up your device first to keep some of your data. You can use Samsung Smart Switch to handle this.
I would then restore your unit to it's most recent OS, I believe Samsung's latest OS is 7.0 with Orea display (I believe that's what it said in the about settings).
All this can be easily done through Samsung Smart Switch.
If not, then you may have to follow the route of S W. Just keep in mind, there is a chance, not that big, that using ODIN to flash a file can overwrite data on the phone, thus losing some information. It's rare, but I've had it happen 1/20 units. Unsure why.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
1) Download stock Tmobile Android 7 from this thread.
https://forum.xda-developers.com/tmobile...
2) You need the latest ODIN or ODIN modified
3) Put your phone in Download Mode
4) Flash back down to Android 7
You may want to use Samsung SmartSwitch to backup your contacts, messages, etc., first.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 65
