跳转到主内容
加入维修社区 - 创建账户
Why does it refuse to boot?
My MacBook Air 11 recently shut down and when I switched it on it went on the apple logo and refuses to log in. I took it to the nearest istore and it came back with 'unit is vintage. Can no longer assess/repair/qoute unit. Apple support no longer support the unit'.
Is this the end of it or something can still be done to repair it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
When you say that it won't log in, does it give the option and just won't accept your log in, or does it only show the apple logo?
完成的
It only shows the apple logo on a white screen.
完成的
添加一条评论
2个答案
最有帮助的答案
Most of the time this is simple a corrupt system folder. First try starting in Safe Mode by holding down the Shift key on start up. Next try booting from and external USB source.
Recently I have seen a couple of the SSD blades fail. Remove the blades, then try booting from an external source.
I forgot, also try booting to the repair partition so you can run Disk Utilities on it. Hold down the option key on boot and select the partition.
这个答案有帮助吗?
得分 3
添加一条评论
Try booting in safe mode.
https://support.apple.com/en-us/HT201262
Follow that guide on how to do it and trouble shoot your issue if you can get into safe mode. If you try safe mode and it still does the same thing, report back and I will help you try to find other things to try.
这个答案有帮助吗?
得分 2
4条评论:
Good answer, we both gave it at the same time ;-)
完成的
@mayer Thanks. And no, i beat you to it. ;-)
完成的
I have tried the safe mode and it does not work also
完成的
www.idownloadblog.com/2015/08/17/how-to-boot-your-mac-in-verbose-mode/
Try verbose and tell us where it stops. Also how long did you leave it run to see if it will eventually boot?
完成的
添加一条评论
添加你的答案
keneilwe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 172
