跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Trackpad and keyboard doesn't work on lock screen
As of the past few days, my macbook will freeze up when it sleeps so when I go back to log in the trackpad and keyboard don't work. I try restarting it 10 times and it doesn't work. The weird thing is, is that when I get it to reset the password during the boot up it both work perfect. And then after probably the 15th time it works, but then will go back to not working when it sleeps again. I don't know if its the trackpad cable or what, but any tips would be awesome.
Update (11/14/2017)
Here is the image:
Update (11/13/2017)
I haven't spilt anything on the keyboard or trackpad before. And here is the image from the coconut battery app.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There is a few possible issues here. The first is your battery is swelling so its pressing on the trackpad ribbon cable. You could review your batteries health using this app: CoconutBattery its a free app which is quite good. Post a screenshot of the main screen for us to see.
The other possibility is you had a liquid spill at some point which is corroded the back side of the trackpad.
As to fixing follow this IFIXIT guide to replace the battery: MacBook Pro 13" Retina Display Early 2015 Battery Replacement. Be aware new rules on the shipment of LiOn batteries prevents shipping by air. So you may mend to find a local source or travel to somewhere where you can buy it.
If the touchpad (trackpad) or the trackpad cable needs replacing then follow this IFIXIT guide: MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement You'll find the part numbers for either parts in the guide.
MacBook Pro 13" Retina Display Early 2015 电池图片
指南
MacBook Pro(13 英寸,配备 Retina 显示屏2015 年初期)电池更换
难度:
困难
45 minutes - 2 hours
MacBook Pro 13" Retina Display Early 2015 触摸板图片
指南
MacBook Pro 13" Retina 显示屏 2015早期 触摸板更换
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 1
添加一条评论
Classic trackpad cable symptoms, very common issue. The cable costs under £10 and is very easy to replace; order one and swap it out
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Grant Saville 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,069
