跳转到主内容
加入维修社区 - 创建账户
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Why can't I shift 2003 Cav manual transmission into any gear?
2003 Cavalier with manual transmission lost ability to shift while shifting from 1st to 2nd. The shifter feels loose now and I am unable to shift into any gear. I am able to move the shifter into the correct positions, but feels loose- like something (shifter linkage?) has become disconnected or broken, and does not move manual transmission into any gear at all. What do you think? Where can I find a free diagram to isolate suspected components?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I am currently having this exact problem. The link to the solution is broken. Any info would be greatly appreciated
完成的
Have the same issue but linkage works fine can't go into gear with or without clutch meaning free play like linkage is broke but on the trans where the linkage is hook to moves freely thanks for any advice
完成的
添加一条评论
2个答案
已选择的解决方案
Sounds like you've dropped the pivot bolt. Here's how to fix it: http://www.dmctalk.com/showthread.php?t=...
这个答案有帮助吗?
得分 3
1条评论:
The link will not load
完成的
添加一条评论
Hi @sarahphill66113
Here's the parts diagram for a 2003 Chev Cavalier manual transmission shift control that may help
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Diver Down 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 4,717
