跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
Loud Fan - Logic board and one of the capacitor bad?
I have an issue with the fans spinning full speed after SMB reset. Otherwise the run fine but CPU only runs half speed.
So... slow ecu or Loud fans are my choice here. Should I resolder the pins on the capacitors?
Thank you so much.
Update 11/15/17
I have installed SSD in place of optical drive and reused the temp sensor so its on the SSD now.
When I do Hard reset the Imac will run on Full Blast, but when I do P R reset the fans quiet down and i can control them by software but the CPU runs only half speed!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Have you changed out the hard drive from the original?
完成的
添加一条评论
1个答案
Hey Paul. Check if this answer attends to you: Faulty CPU/ODD sensors or fans after Dual Drive Kit Upgrade
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 93
