跳转到主内容
An in-car GPS manufactured in 2012 by Garmin.
10 个问题 查看全部
My 3590LM has intermittent contact when I put it in the mount.
Apparently there is a contacting Problem with the 10-pos. connector between the device and the Mount.
The power connection is intermittent as well as the connection to the speaker inside the mount.
This Results in no Sound at all, Since the device-internal speaker apparently is Turned off, when the the device is put in the Mount.
Does anybody have the Same Problem and/Or know the Signal Descriptions/Pin designations of this connector?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
If you are referring to this part:
It can be found on Ebay for about $30USD.
这个答案有帮助吗?
得分 0
添加一条评论
Thank you for the quick response.
This is most likely the correct solution, but doesn't help me right now.
I am leaving for a trip of about 1500 km today, from Tarragona in Spain to Stuttgart/Germany with Stops in several French towns.
Yesterday I opened the mount and found out that it contains an electronics board.
I cleaned the contacts, using a toothpick and aftershave.
It seems to bring an improvement, at least it charges and the lady talks to me again.
Hope it lasts until I'm home and can buy a new part.
这个答案有帮助吗?
得分 0
1条评论:
Great! please mark this question answered then. Thanks!
完成的
添加一条评论
Well, the improvement by cleaning did not last very long.
I endet up, connecting the device to an alternative USB-supply instead of using the mount.
Before I spend money buying a new mount, I'm still trying to find out whether the problem lies in the mount or in the device.
Maybe I'll find somebody, who has the same unit, but still working.
这个答案有帮助吗?
得分 0
添加一条评论
i have the same problem with the wife’s 3590, but mounting my 3590 in her bracket has no problems.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lothar Meininger (el_mundi) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 166
