跳转到主内容
Released June 2014, identified by model number 15-d076nr
7 个问题 查看全部
Laptop screen not working
I cleaned my laptop with Colin a general glass n stuffs cleaner liquid ...then on starting up it initially made a white screen on Windows 10 startup I unplugged the laptop and booted again same thing occurred ...the next time on it didn't even show the BIOS screen on startup ...but I can see the CPU lights blinking ...and a little spank on the screen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
You might have liquid-damaged the screen when you cleaned it.
Try shining a flashlight on to your screen to see if only the backlight is the problem. If you can barely see stuff on your screen it's only the backlight that needs to be replaced.
If however you can't see a thing on your screen even with a flashlight, plug it into an external monitor or TV, see if it detects your laptop as a source and shows content. If this works, replace the LCD panel.
这个答案有帮助吗?
得分 3
1条评论:
Thanks fr the reply
完成的
添加一条评论
添加你的答案
Indranil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 397
