跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
On/Off switch works only when left side of phone is held...
Just to make sure I'm on the right track, my iPhone 3Gs' sleep/lock button and up volume switch only works when the left side of the phone is pressed together. Also, I have low volume (even with the setting all the way up) in some apps, keyclicks, specifically. Does that indicate a problem with the headphone jack assembly?
Thanks for any help you can provide!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi, Terry,
I don't know if anything new has been done...maybe it's because the phone has been dropped? I will make an attempt to open the phone and check for that contact... Thanks for the direction!
完成的
try reseating headphone jack connector 5 or 6 (can never remember which one- it's the square one) onto motherboard. it's on the left side of phone and may just have come loose.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Michael, If you've had a new screen digitizer or lcd fitted, some times the tiny contact metal strip just misses it's contact point easy fix just open phone & bend clip until you get it to work
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,555
