跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Call audio too low
Replaced my LCD and digitizer (cracked). After reassembly, the received audio from the upper speaker was low and scratchy. I cleaned it, it got only a little better. Volume buttons don't help. If I use headphones, bluetooth, I can hear fine, volume buttons work on those.
If I turn on the call to the speakerphone, the volume is loud, but the other party stops hearing me. This is a different set of symptoms from other similar call audio problems on your site.
I may have pulled the ribbon cable on the headphone jack.
I assume the headphone jack needs replacing, but I wanted to see if I need something else because of the way the speakerphone option is acting.
Thanks in advance,
Commander Winc
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If bluetooth is working on the phone, try an FM bluetooth transmitter to send to an empty car radio station directly.
https://www.amazon.com/Nulaxy-Wireless-B...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
John Wisniewski 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 162
