Backside Metal or Plastic?
Is the iPhone 8's backside under the glass of metal or plastic?
Thank you.
It looks like steel to me.
The spot welds along the edge of the studs are bluish which is what steel would look like. In addition the thinness of the metal given the needed strength would imply steel as well. True the outer side edge is anodized aluminum!
这个答案有帮助吗?
It is metal. See this phone
这个答案有帮助吗?
Mandy you are correct. It is made from stainless steel.
It is metal covered with glass, however i don,t recommend this phone if you want a strong one a video from the channel jerryrigeverything the back glass broke dramatically after only the second from lap fall . If you a good powerful phone i would recommend the xperia xz premium.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 34
总计 814
