跳转到主内容
This Power Mac G4 has Mirrored Drive Doors.
Sound not Working Neither on startup or in OS
I recently acquired a Power Mac G4 MDD in which the sound does not work.
I'm fairly new with Macs, so I don't know what to try
The speaker on the computer looks blown, but any external speakers I try don't work on any of the ports.
I've tried putting in an SB Audigy and Audigy 2, neither of them got picked up in Mac OS
The only resemblance of sound is a little speaker pop on startup
I'm stumped, can anyone help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Let's first see if it is the preferences. Go to System Preferences > Sound and see how it is set for out put. Plug the external speakers in (make sure they are not ones than need a special driver). Put the sound on line out. Make sure you selected the speaker port and not the microphone port. Let me know your results.
If I need to I can play with one of my two MDD machines. Are you running 10.5.8?
这个答案有帮助吗?
得分 1
2条评论:
I tried this, and it was switching between line out and internal speaker.
No, I'm running 10.4.11, but I'll try 10.5 in a few days
完成的
Also, if it helps, it lags when I press volume up and down on the keyboard.
完成的
添加一条评论
I think I found the problem
Yesterday, I was using this computer with the ADC monitor I got with it, and all of a sudden, the bottom backlight went out.
I was confused, so I rebooted the thing, the monitor was fine at first, then it went out again.
I decided to test another video card, same problem.
I hooked up that monitor to my 2002 G4 QuickSilver, and then it worked just fine, so I believe the power supply is failing, and thus might be the reason for the audio not working.
Could I possibly use the PSU from my QuickSilver to test if it was the PSU, or would it consume too much power?
这个答案有帮助吗?
得分 0
1条评论:
If the power supply pins and voltages are the same for both computers then it will likely work ok for the test. The wattage rating should be in the same ballpark, either higher for the good supply or > 75% of the rating of the bad one. I don't know if Macs use a standard ATX pin connection but see if the wire colors match between supplies before using. Power supplies don't usually fail by getting weaker but maybe something in the Power Mac G4 is drawing too much current or a voltage is out of spec. Check the voltages with a DVM if you have one and they should be within +/-5% of rating. Here is one site that might help. itstillworks.com/test-supply-power-mac-g4-7254045.html (no www.)
完成的
添加一条评论
添加你的答案
Robinton Santos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 362
