Computer runs perfect on battery only. It does not take charge.
When it 's plugged into de wall, it doesn't take the charge nor the light in the mag plug stays lit. The little green light blinks only. Otherwise, when it works on battery, the functions are normal. The battery is almost new. The charger works fine in other computers. What do I need please, and how much it costs?
Thank you.
Jorge Barreiro
13条评论
I received the parts and tools needed for the replacement of the Left I/O Board and followed the instructions exactly as instructed. The result is the same blinking green light and now the computer doesn't power on (The battery is showing only one light, so, it may be drained)
What can I do?
What could've go wrong?
Was the diagnostic wrong?
Please help me.
由 JORGE BARREIRO 完成的
If the battery gets to low the machine will not power up. Leave it plugged in for an hour, let the battery charge and try again.
由 mayer 完成的
Thank you Mayer for your replay. I don't think the battery is charging, since the mag plug doesn't show a consistent green light. It's been plugged for about 40 min. now and the green light is still blinking.
Hello Mayer, the situation is the same, battery not charging, green light blinking and it's already 1 1/2 hours. What should I do?
Hello Mayer or anybody else, I desperately need help, please!
显示更多的8条评论
