跳转到主内容
加入维修社区 - 创建账户
MacBook Pro Won't power on at all!
This is a real odd one! My friend's MacBook Pro had a broken O key, so he took it apart to replace the keyboard, but didn't know how to put it together so he gave it to me. I meticulously reassembled the machine, and now it won't power on! When plugged in the green light comes on the magsafe charger, and the battery indicators light up fine. Then, the sleep light start s to fade in, but abruptly stops. If you listen very very closely you can hear the fan initiate then stop in time with the sleep light. Took it to the Apple store where the technician said he couldn't figure out what was wrong, but that everything seemed to be assembled correctly. Have already tried SMC and NVRAM resets to no avail.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
How did you fix the keyboard? Did you replace the upper case or did you get the keyboard unit and put it in?
完成的
添加一条评论
1个答案
最有帮助的答案
See if it will spontaneously boot. Remove mag-safe. Unplug battery. Press & hold power button for ten seconds. Reconnect battery and mag-safe. You should get a boot. Then see what you can find out.
这个答案有帮助吗?
得分 2
1条评论:
I did try removing the battery and using the Power Adapter, and at the Apple Store the technician tried that method to jump start the machine, the same sleep light/ fan sequence occurred.
完成的
添加一条评论
添加你的答案
Luke Miani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 159
