跳转到主内容
Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
Can you replace components of an external drive enclosure?
I can no longer get this Lacie 2tb Dual drive to mount. I've suffered through many failed hard drives, and it appears that the actual SATA drives inside are working properly.
I think that there is a problem with the power supply (or something related). The fan no longer works.
The trouble is that this 2tb drive is made up of two separate internal drives. Ordinarily I would just put them in another enclosure. But these drives are formatted to be perceived as one by the computer. When I try to mount one on its own, the computer doesn't recognize the format and asks for it to be initialized or ejected.
My understanding is that when the two drives work together in this manner, it doesn't work to simply put them in a new dual drive enclosure by a random manufacturer. I do have one on order, but I don't know if it will work.
So the question is: is it possible to repair my existing enclosure?
Any ideas as to which part would need to be replaced and where to get one?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I'm using this drive with ProTools to record audio. Presumably you're not allowed to record audio in ProTools to a RAID drive. So I don't know if it's a proper RAID configuration.
All I know is that it's sold as a 2TB hard drive, and when you open it there are 2 1tb drives inside.
完成的
添加一条评论
2个答案
最有帮助的答案
Email to: kcummings@lacie.com and cryan@lacie.com Karen is your best bet.
Tell them your problem and see if they might be able to assist you. Include exactly which drive you have
这个答案有帮助吗?
得分 1
添加一条评论
I am assuming you had them in a RAID 0 configuration. Now therein lies the problem. Assuming the LaCie uses a standard RAID 0 config and no customizations that would make it proprietary, you can buy any one of these and pop the HDDs back in to access the data.
PS: Back up your data on a RAID 1 or a single drive next time
PSS: RAID 0, in case you don't know what it is, means that you would need both drives in order to access data. The loss of one of these drives causes you to lose all data.
PSSS: A more secure method of backup (more than RAID 1) is RAID 5 and RAID 6
这个答案有帮助吗?
得分 0
1条评论:
So I bought an external enclosure, and my mac is saying, when I plug it in, that it's an unrecognizable format and requires initialization.
this would lead me to believe that there is a proprietary LaCie RAID configuration.
完成的
添加一条评论
添加你的答案
eatvtn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,421
