跳转到主内容
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
20 个问题 查看全部
Ripped tape from LCD to Speakers, is this a problem?
When removing the LCD, I tore the tape while trying to remove it.
Its the pieces from the LCD along the bottom onto the speakers.
Are those essential for electrical contact?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Do you mean the tape at Step 45 of this guide?
It's not ideal but I don't think it makes a lot of difference either way. Sometimes the tape just won't adhere properly (like during a second repair) and it causes no issues. So I doubt the tape being torn would cause any issues.
这个答案有帮助吗?
得分 2
2条评论:
That's it, thank you.
I'm just concerned because now the home button isn't responding.
Maybe it's the new digitizer assembly?
完成的
Probably, however there are a lot of gotcha's when it comes to properly assembling a mini digitizer. Make sure the bottom of the digi looks like this picture (iPad Mini Wi-Fi前面板组件更换). If you see exposed contacts like on Step 62, you need to cover those with an anti-static tape (Kapton).
完成的
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 97
