跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
New iMac 5k 2017 CPU is Upgradable?
Hey! This Summer i bought a new 2017 5K iMac with a i5 7600k.
So... The New Intel CPU 8700K is now available!
I just want know can I replace my i5 7600k to the new i7 8700k?
Is it possible to upgrade?
Thank You So Much
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 15
1条评论
I've just upgraded my imac 2017 with an i9 9900 with no issues. Just don't mix up the 9900 with the k version as that is not supported due to power output needed being greater
完成的
添加一条评论
9个答案
已选择的解决方案
Here's a better vid on upgrading this system: The Best 2017 iMac Apple Doesn't Sell! Quinn only installed a i7-7700k
As far as the still newer Intel i7-8700k Apple hasn't used it yet in any of their systems and the micro code in the EFI won’t allow it. The best this system will support is a 4.2 GHz Core i7 (I7-7700K).
In any case keep in mind you'll be voiding your warranty here! And pulling off the display without using the correct tools and technique can kill it which would be an expensive Oops!
这个答案有帮助吗?
得分 6
添加一条评论
最有帮助的答案
You will NOT be able to swap for the 8700 but you WILL be able to swap for the 7700 with no issues what so ever, literally on boot-up the system will immediately recognize the new CPU. The 8700 is a 6 core chip and they don't have any EFI to support that with the current OS. The iMac Pro doesn't even use the new Coffee Lake chip, so it may be doable in the future, but not as of yet. BTW, the latest iMac Pro uses Xeon chips for multi-threading and a kick-ass GPU, so that one will be upgradeable in the future. Hopefully, Apple will come up with some OS updates and the new 8th gen Intel chips will benefit.
这个答案有帮助吗?
得分 9
7条评论:
Will the 8700 work now in such an iMac with the new High Sierra or Mojave updates?
完成的
Jiri, Will the 8700 work in a 2017 imac as of now with the latest High Sierra or better yet, Mojave updates?
完成的
Zack - Jiri believes the 8700 will not work and I second that! Again you can't run newer CPUs unless the system has the ability to support it. In this case both the TDP and the systems micro-code won't allow it.
完成的
Sorry I'm late to this question. The answer for the time being is that the 8700 cannot be used, mostly due to architecture (6 core vs 4 core) and the lack of instructions on the Mac boards. The 2018 Macs may cover the newer chip, but we won't really know that until September. Just so you know, unless you plan to run extremely intensive programs, the 7700 will do super fine. The TDP is fairly high for the 7700K swap, so I would personally recommend the T series for both better thermals and overall better per watt performance. I prefer the 7700T chip, also the 6700T chip is a winner IMHO.
完成的
Also, quick brainstorm to address newer versions of Mac OS - the software won't affect how the hardware operates, they cannot write in EFI code to 'make' the 8th gen chips 'fit.' This is a matter of hardware, although there may be BIOS updates to the mother boards, but keep in mind that Apple isn't encouraging changes to their hardware, so BIOS miracles are doubtful at best. I would agree that the 8th gen chips have better performance and thermals over the 7th gen, but again, I recommend T chips over the regular ones, and also recommend regular chips over the K unlocked version, mostly due to cooling concerns in the cramped and under-cooled Mac enclosure. The T chips are factory undervolted and they have amazing thermals.
完成的
显示更多的2条评论
添加一条评论
I have successfully upgraded my iMac (Retina 5K, 27-inch, 2017) with an Intel i7-7700 and a 2TB Samsung 970 EVO NVME SSD. Please see post below for full details.
https://forums.macrumors.com/threads/ima...
Thanks.
这个答案有帮助吗?
得分 4
添加一条评论
I don't know much about Macs, but I do know they much prefer people buy new things instead of upgrading. My guess is no, but it looks the people here might know better:
https://9to5mac.com/2017/07/17/imac-upgr...
From what I read, it sounds pretty intense. Best of luck, I hope it works
这个答案有帮助吗?
得分 1
2条评论:
If you don't know much about Macs, I suggest you don't comment.
完成的
Thats OK Paul, Chase is only repeating what I posted.
完成的
添加一条评论
Hi guys.
I have same question as well. My iMac is same model which is Mid 2017 i5 processor. But time already 2019 which does it upgradeable to i7 eight or nine generation?
这个答案有帮助吗?
得分 0
2条评论:
Yes, I am wondering the same.
Some post said that chipset and volt usage are different, but it's been 3 years, I wonder if someone or apple has come up with new EFI?
完成的
Apple is the only source for the system firmware. While they do update it time-to-time they don't alter the microcode within the series to support newer chips.
So in your case the 2017 27" iMac can support only this chips iMac18,3. The highest performer in this series is a 4.2 GHz Core i7 (I7-7700K) CPU.
完成的
添加一条评论
You can upgrade only to what Apple offered for this iMac, so an i7-7700K CPU (K is important). No i9 or different i7.
这个答案有帮助吗?
得分 0
添加一条评论
But can I upgrade to a i7-8700k with mac os Mojave?
这个答案有帮助吗?
得分 -1
1条评论:
Nope! Can't be done the i7-8700 is not supported in the 2017 27" iMac.
The best you can go to is a 4.2 GHz Core i7 (I7-7700K).
完成的
添加一条评论
oops! why I can’t log-in to ifixit by Google account anymore?!
I'm a bit confused! Now in macOS Mojave, is it possible to do that? or hardware doesn’t accept it!
Anyway. I’m going to bring my iMac 5K 2017 to London apple store and ask them to instal high-end CPU that it’s possible into it. :)
But, if I can replace i5 to i7 8700K, I will do that by myself. I just wanted to ask is it possible with 2017 iMac hardware condition or not. Because, I already knew that Apple will release an update for 8 generation Intel CPUs.
这个答案有帮助吗?
得分 -1
2条评论:
you' probably need a new MOBO to install the 8th gen intel chips
完成的
Nope just not possible! The best you can go to is a 4.2 GHz Core i7 (I7-7700K).
完成的
添加一条评论
It could be done. Using an 8 gen I7 on H110 is possible now. And many articles claimed that 6 7 8 9 gen core CPU are compatible with each other’s socket. So, here is my guess: 1 If we need 8th 6core CPU installed, Some modification on the socket pins is necessary which is referred to some tutorials. 2 When Apple release new EFI to new coffee lake devices, can we transfer it back to this iMac?
That all, may this be helpful.
这个答案有帮助吗?
得分 -2
1条评论:
Apple is not rolling out a new EFI for this series which has newer micro code! There is other factors here than the EFI! First is the Power supply and the second is the thermal load the logic board is not designed to support anything but a 4.2 GHz Core i7 (I7-7700K) as the highest CPU.
完成的
添加一条评论
添加你的答案
Javid AJ 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 34
过去 30 天: 118
总计 49,233
