跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
iPhone won't restore when plugged into iTunes
The phone all the sudden stopped working so I decided to restore it. When I hold the power and home button the display is blank but iTunes says its in recovery mode. I downloaded the ipsw and started the restore, I saw an apple logo and the loading bar under it but even after leaving it all night the bar made 0% progress. can anyone help??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you saw a blank screen after pressing those buttons but iTunes said you were in recovery mode, you successfully entered DFU mode.
It sounds like iTunes is giving you grief so, try using 3utools to flash instead of iTunes.
这个答案有帮助吗?
得分 1
2条评论:
Thanks, I used the tool but it said "invalid serial number" do you know how to fix that?
完成的
Try
a) Taking out the SIM Card
b) use DFU mode (I assume you are already doing so)
c) If this is PC, check device manager to see if there are any errors around your iPhone listed.
If these don't resolve your issue, you may have hardware damage around the charge/data port.
完成的
添加一条评论
添加你的答案
Maxton Fanberg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 293
